silencer ring?
Old Oct 24, 2006 | 04:59 PM
somis13's Avatar
silencer ring?
what is the primary function of the silencer ring and why do poeple remove it
Old Oct 24, 2006 | 05:41 PM
displacedtexan's Avatar
Exactly what it sounds like it would do, reduce turbo noise, the only reason to remove it is to make the turbo more audiable. No performance reason to remove it, or leave it in...
Old Oct 24, 2006 | 07:07 PM
Forrest Nearing's Avatar
turbos with very small turbine housings will benefit from removal of the ring as it allows the MWE slot to do its job better
Old Oct 24, 2006 | 07:42 PM
gman07's Avatar
I believe Holset calls it an "inlet baffle", and I believe it slightly increases compressor efficiency by creating more laminar flow. I used to think it was just to reduce noise on Dodge trucks, but I've seen it now in other Holset applications.
Of course, I still don't run a silencer ring because I love the noise
Old Oct 24, 2006 | 08:41 PM
mysterystench's Avatar
I removed mine the day after I got my truck, a month later and i just put in the BHAF....
all I can say is WOW
If you like the noise, no ring is the way to go!
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
