a 'shutter' when the trans shifts into O/D.
Old Nov 9, 2006 | 03:28 PM
b.lee's Avatar
I just picked up my first CTD after dreaming about it for 2 years.
Anyways, just like any used vechicle it has its fair share of problems,
The major problem is a "shuttering" or shaking motion when the truck shifts into final overdrive.
when I am on the throttle thru the gears it shifts fine.
and it shifts thru all other gears fine.
its usually only when im speeding up at a slower rate while it shifts into final overdrive.
its a 2500 96 Auto 4x4 Ext Cab , and alot of miles.
its only had one owner until I bought it today.
anyways, some help would be great.
thanks.
Old Nov 9, 2006 | 03:32 PM
Lil Dog's Avatar
Typically the shudder you feel is the torque converter trying to lock up. The shudder can be an early symptom of wear to the torque converter clutch.
Nice ride BTW!!!
Old Nov 9, 2006 | 04:03 PM
Mcmopar's Avatar
What you are describing as shudder is as stated above, the T/C, the truck is probably already in OD. Lock out OD and drive the truck, if it still does it, it is probably the TC for sure. The only way to "FIX" this is with a new converter. But, that being said you "might" be able to bandaid it for a while with a new VB from someone who gets the line pressure up and also opens the exhaust port so the TC locks up a whole lot faster. I suggest that you call Dave Goerend at 563-778-2719.
Tell him Phil sent you. He is the owner of Goerend Transmissions.
Old Nov 9, 2006 | 04:04 PM
Mcmopar's Avatar
BTW, nice looking truck!! I am sure you will enjoy it!!
Old Nov 9, 2006 | 07:21 PM
infidel's Avatar
Try adjusting your TPS it may be kicking into OD at too low of a mph.
I usually keep the OD off engaged until I'm going over fifty and intend to keep going at least that fast. It will make your tranny last longer.
TPS instructions > http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Old Nov 9, 2006 | 08:21 PM
b.lee's Avatar
thank you all for the info and the comments so far.
Old Nov 10, 2006 | 03:10 PM
b.lee's Avatar
Can anyone tell me the location of the 'TPS' ?
I read the instructions above, but it doesn't tell the location of it.
or else I missed it.
Old Nov 10, 2006 | 03:56 PM
Mcmopar's Avatar
Front driver side of the engine, near where all the throttle linkeage and cables go, you will see the connector.
Old Nov 10, 2006 | 06:52 PM
infidel's Avatar
Follow the only wires that go to your injection pump.
Badd Dogg Guy19
Jan 28, 2011 11:00 AM
VikingDiesel
Nov 30, 2010 06:15 PM
spdnby
Sep 1, 2010 10:12 PM
southerngal
Jan 10, 2007 08:37 PM
bigbaddiesel
Nov 23, 2002 02:33 PM
