Shifter mounted OD switch in a 95?
Old Aug 21, 2009 | 04:33 PM
kas83's Avatar
Is it possible to get it to work if I take the shifter and wiring from a newer truck? Looking to put some gauges in place of the cupholder and OD switch in the dash if possible.
Old Aug 21, 2009 | 07:00 PM
96_12V's Avatar
Maybe you could relocate it to the Overhead console?
Or just order an A-pillar gauge setup?
Old Aug 21, 2009 | 07:09 PM
infidel's Avatar
Don't see why it wouldn't work.
The OD switch is just momentary contact, you'll have to rig up a light though and most likely a relay to power it.
Old Aug 22, 2009 | 10:14 AM
Cowboy_Customs's Avatar
It can be done, the 1st gen guys have done it. Poke around down there, I know I read an article on it a few months ago, maybe not that long ago. I think it was pretty simple too.
Old Aug 22, 2009 | 03:26 PM
kas83's Avatar
Thanks, I searched it and found immediately. Just need to figure out the indicator so that I know when overdrive is off.
Old Aug 22, 2009 | 06:40 PM
infidel's Avatar
If the column switch is the same as the dash wiring wise their are two sets of contacts, one set for the od that switches a ground signal while the other set switches positive for the light.
The dash switch also has another set of contacts for the indicator light that's connected to the headlight dimmer circuit.
The column switch won't have this extra set.
ScienceOfSpeed
0
May 14, 2007 12:46 AM
3Sigma
Oct 26, 2006 09:18 AM
budsowner
Jan 9, 2005 11:27 PM
Ben
Mar 6, 2004 09:53 PM
Buzz
15
Aug 21, 2003 12:09 AM
