Shift-on-the-fly speed limit?
Old Dec 5, 2007 | 11:32 PM
Hercules's Avatar
I can't find my owners manual or even my shop manual to answer this, so, here it goes. At what speed is the limit for shifting into 4 wheel drive in the truck in my sig? Also, since this is the first truck I've owned that has a manual transmission I figure I should ask this too...should I push the clutch in while I put it in 4 wheel drive(while moving)? My last Ram had an auto trans and all I did was let off the gas, pull the shifter to engage 4wd, then get back on the gas. I guessing its the same proceedure for the nv4500, just want to make sure. Thanks!
Old Dec 5, 2007 | 11:59 PM
kelownadiesel's Avatar
I put my 5 speed into neutral and slow it to like 80km and hour .Goes in fine.Tried it in gear one time and it ground a little
Old Dec 6, 2007 | 12:05 AM
Fishin2Deep4U's Avatar
I think my manual said to engage no higher than 55mph.
I can tell you that it will engage at speeds up to 110mph.
Dave
Old Dec 6, 2007 | 10:34 AM
strokerace's Avatar
I read somewhere that 55 mph was the max shift on fly speed
Old Dec 6, 2007 | 10:47 AM
Hercules's Avatar
Thanks for the info! I figure with the snow finally falling here it would be good to know. All summer I've only had to shift into 4wd from a stop and it was more of a precautionary measure since I was backing up to a drop-off on loose dirt sloped toward the drop to dump debris...I wanted to make sure I could pull out. Thanks again!
Old Dec 6, 2007 | 11:23 PM
West Coast's Avatar
Hercules I always put the clutch in to shift into 4 HI. And let of the gas pedal a little when shifting.... Should go into 4 wheel nice and smooth.... A lot of time I will even slow down to make the shift even easier...
coreydr2003
Feb 11, 2008 07:21 PM
Thundercloud
Sep 24, 2006 01:04 AM
pet05
Apr 20, 2006 09:35 AM
BA05'CTD
15
Jun 15, 2005 12:28 AM
commtrd
22
Jul 1, 2003 09:19 PM
