settting injection timing
Old Dec 25, 2003 | 08:57 AM
JM_1's Avatar
does anyone know where i can find information on setting timing i have a 1996 dodge 3500 im putting a new injection pump in any information would be appreciated.
Old Dec 25, 2003 | 09:57 AM
infidel's Avatar
Complete instructions here with tool part numbers
http://dodgeram.info/tsb/1994/18-10-94a.htm
Chart here-
http://dodgeram.org/tech/dsl/FAQ/timing.htm
Old Dec 27, 2003 | 08:22 PM
HammerMTB's Avatar
Setting timing on pump replacement
Cummins set it up so you don't have to have special tools to install a pump when R & R'ing it. If you are going to replace your pump, set the engine to TDC#1. Pull your old pump. Your new pump will come set to spec for installation at engine TDC. Pull the lock pin to check it. Put the lock pin back. Then, if you want to run extra advance, move your engine opposite the direction of rotation by the amount you want to advance. Complete your installation as normal. VIOLA! you got the job done without special tools! How much do you turn the engine, you ask? If you want a degree wheel paper tab for this, PM me and I'll send you one in a scanned file. Then just make a pointer and move the amount you want.
Old Dec 28, 2003 | 01:12 PM
Monty's Avatar
Or, you can use this link to the tech facts section.
Degree Tape
Old Dec 28, 2003 | 01:26 PM
HammerMTB's Avatar
Hey, it's up!
Thanks, Monty! You da man!
Old Dec 28, 2003 | 01:32 PM
HammerMTB's Avatar
Malfunction!
I'm not sure how to do it, Monty, but the degree tape will have to print as 8.5" by 11". When I printed one just now it came out about 4" by 4.5" so the distances are all wrong. Is there anything we can do to make it a full sheet of paper?
Old Dec 28, 2003 | 01:41 PM
Monty's Avatar
Hmm..let me play around with it and see what I can come up with.
BTW...it has been up for about a week now..I just forgot to tell ya Thanks again.
Old Dec 28, 2003 | 01:57 PM
Monty's Avatar
Hammer, I just printed one and the full drawing fills a full size sheet of paper. Does the whole drawing need to fill a full size sheet or just one tape of the drawing? If so, which one is needed? Thank ya sir.
Old Dec 28, 2003 | 02:29 PM
HammerMTB's Avatar
1 sheet for all
The whole thing is one sheet. So you get any tape you need, and for most 2 copies, from one sheet of paper. I'll go print another, and see what it does now!
Old Dec 28, 2003 | 02:33 PM
Monty's Avatar
When you get to this link click on the picture and it will make it full size.
Old Dec 30, 2003 | 09:27 PM
1dslram's Avatar
Once you have the full size page right click on the page and click on PRINT PICTURE and you will get a full size print.
Bruce
tommurray
Feb 23, 2014 10:38 AM
ViperSBT
Jun 21, 2005 06:22 PM
eastmentCTD600
14
Mar 11, 2005 10:00 PM
JMAHAN
Aug 18, 2004 02:33 PM
