Seems to loose power on hills...
Old Jul 14, 2011 | 08:07 PM
zthatzmanz28's Avatar
So our 98 12 valve is running good. Since we have been hauling our 11K pound fifth wheel around the Great Lakes, there are times when it seems to loose its get up and go.
We will be coming up on a hill, shut off OD, and the truck is going 60 MPH and slowly loses speed until it gets to around 35 mph.
Skinny pedal is down and the rpms are around 2000 steady. The truck just plods along until it crests the hill and it slowly gains speed.
If we stop for 30-45 minutes and continue down the road it is fine...
It is a stock trans, and no mods on the engine.
THANKS
Old Jul 14, 2011 | 10:45 PM
greasy's Avatar
hows your fuel pressure?
Old Jul 15, 2011 | 06:01 AM
Don't have a gauge (ya I know) but there is a Torx OFV. I do have the potentiometer installed.
At WOT it just crawls up the hills sometimes...
Old Jul 15, 2011 | 11:05 AM
Lil Dog's Avatar
Boost? EGT? That may help to troubleshoot.
Old Jul 15, 2011 | 08:10 PM
whiskers's Avatar
If it's maintaining rpms I have to think torque converter slipping.
Old Jul 15, 2011 | 09:00 PM
I am slacking in the gauge department...
I am thinking it possibly might be the fuel filter? Wouldn't the RPMs race if the TC was slipping? It feels like something is holding or pulling the truck backwards as I climb the hills. We are talking 1-2 mile grades. I know the trans probably needs a few upgrades like a valve body, TC and maybe clutches...but it seems to be OK. Not that I would try competetion pulling with it as it is.
I am going to replace the fuel filter and install an auxillary cooler on the tranny when I get to Detroit on Monday.
Old Jul 16, 2011 | 10:16 AM
Lil Dog's Avatar
If the tranny is already slipping, the cooler isn't going to help much. The damage is done.
Old Jul 20, 2011 | 12:25 PM
So once again, the Dodge already has a pretty stout transmission cooler installed by PO. Seems to be a fuel flow issue. CHanged the fuel filter and it runs a little better.
What are the chances it is the lift pump or the P7100?
Who has a good replacement injection pump?
Old Jul 20, 2011 | 04:13 PM
patdaly's Avatar
Here again, you can spend thousands of dollars throwing pumps at it, and unless you are SURE you have 22-25 PSI at idle and 32-35 PSI at WOT, you will just be throwing good money after bad.
The P7100 is not a pump that has problems.
I know you have that fancy overflow valve, but without knowing what the fuel pressure is, you have no idea if it is helping, or hurting you.
Old Jul 21, 2011 | 12:40 AM
Tate's Avatar
Just to clarify, fuel pressure would decrease at WOT under load. The 32-35 psi spec is at 2500 rpm, no load.
Old Jul 21, 2011 | 07:27 AM
patdaly's Avatar
LOL, Must not have mine loaded enough then, she sets rock steady at 35 PSI at WOT.
But yea, 2500 RPMs is the official number.
Old Jul 23, 2011 | 04:50 PM
THanks.
I made it over the Appalachians (I-77) and the Dodge did better with a fuel filter change.
The coming weeks I am going to add gauges (Fuel, Boost, EGT) and then some temp gauges later...
I have 1 month before going back to work and would like to swap out the dash and harness before starting the gauges and engine mods.
Old Jul 23, 2011 | 10:50 PM
Tate's Avatar
Just need more fuel. 13mm pump sucks down the pressure a bit.
Old Jul 24, 2011 | 12:53 PM
patdaly's Avatar
I have heard that situation is akin to taking crack cocaine....... a huge slide towards financial ruins..........
But soon enough, I may just do it anyway......
Leaky Gasket
Aug 14, 2008 07:17 AM
johnjudge
Feb 16, 2004 07:52 PM
cscobb1
Aug 10, 2003 10:22 PM
jdcott1
Oct 22, 2002 02:13 PM
jdcott1
Oct 20, 2002 11:48 PM
