sector shaft play
Old Apr 5, 2006 | 07:20 AM
simonswb6's Avatar
sector shaft play
i have the death wabble. i had someone move the steering while parked and noticed a lot of play coming out of the sector shaft. is there supposed to be any play? or is this an indication that the steering box is bad?
also i have read that there is an adjustment at the top of the box. what does this do?
Old Apr 5, 2006 | 11:34 AM
vssman's Avatar
The box has wear in it. Sector shaft play is adjustable. There is a procedure to do this but the basics are:
1) Remove the I-shaft from the input shaft on the box.
2) Loosen the lock ring with a punch holding the adjusting ring in place.
3) Using a spanner wrench (I use 2 narrow tip punches) tighten the lock nut and loosen it back a bit (I don't remember how much "a bit" is - I tightened mine snug and left it there)
4) Replace the lock nut without turning the adjusting ring
5) Reinstall the I shaft.
A DSS also helps eliminate sector shaft play.
Mountaineer
18
Sep 1, 2012 10:51 AM
joshworthy21
Jul 28, 2008 11:38 AM
TexasCTD
38
Sep 21, 2007 09:51 AM
csramsey640
May 29, 2006 09:42 AM
newriverSpecon
Apr 25, 2006 08:11 PM
