searching for an nv-4500
Old Jul 28, 2009 | 03:01 PM
war machine's Avatar
okay guys, I am looking for an nv-4500 for my truck (doing a swap from automatic) and it seems to be that there is a very short supply of these transmissions here in ontario, except for in the older chevrolets,gm's, and v-8 dodges.
my question is: does anybody know if there is any particular year in which the GM nv-4500 had the same input & output shafts,spline count and transfer-case bolt pattern as the dodge nv-4500?? or if I can disassemble the transmission and install the dodge input and outut shafts??
same goes for the nv4500's found in the dodge trucks with the 5.9 gas v-8.
can they be made to work?? because ther's plenty of these transmissions around, just none specificaly for the cummins application.
Old Jul 31, 2009 | 09:24 PM
frmll300's Avatar
Have you spoke with Heath at Hot Rod Diesel? He may have a trans. or know where to get one.
Whereabouts in Ontario are you?
Old Aug 1, 2009 | 12:41 AM
95black2615's Avatar
I ended up buying a 2wd dodge nv-4500. I had to change the mainshaft in the tranny and rear housing to convert it to 4wd.
Old Aug 1, 2009 | 02:10 AM
seahawkdodge's Avatar
I have an NV4500 you can have. All you have to do is trade me a NV5600 for it...
Old Aug 1, 2009 | 06:08 AM
well, frmll300, I havent been to hotrod diesel, are they in ontario?? I'm around barrie ways, so diesel speed parts etc... are expensive and somtimes hard to get.
I am thinking I am going to have to buy a 2x4 transmission and then convert it to 4x4. I know where I can find an nv4500 from a bus, it also had a 12 valve in it, so that may work. how was it changing out the mainshaft and rear housing?? because like I said earlier I am probably going to have to go this route.
Old Aug 1, 2009 | 09:51 PM
Ron E's Avatar
You can go to "car-part.com" and follow instructions. Find them, warranty info, by distance from you and/or prices.
wantedwolf
27
Apr 15, 2009 11:23 PM
v8440
Apr 10, 2006 04:05 PM
slttork
Mar 20, 2004 08:39 PM
Crimedog
Jan 21, 2004 07:22 AM
McGyver
Dec 10, 2002 09:37 PM
