Sad sad day!
I doubt it is hydrolocked with oil or water unless you drove it through a lake. If it's seized up it's because one or more pistons are melted to the engine block cylinder walls.
Sorry for your bad luck, better include gauges in the new motor build-up
Originally Posted by 74dart
The gauges are a definite also will the motor be saveable if one or more of the pistons are metled to the cylinderwalls. I know it will have to be bored out but I would like to keep the block if possible. Also should I go to a larger turbo a 14 maybe?
There are tons of turbo options out there, you can get a modified HX-35 or and HX-40, or get BD's single turbo ( which can be upgraded to twins
)....depends on if you are happy where you were or would like a tad bit more juice?~Nick
