Running rich
Old Jul 26, 2014 | 10:09 PM
oldschoolshovel's Avatar
Running rich
I have read that a diesel can't run rich. But I don't know how else to explain it. I have a 1997 bone stock 215 hp 12 valve. When I'm hooking up a trailer with it running it will burn your eyes like crazy. If I had to say what smoke it has I would say blue I know blue means oil but this smells like fuel. Has anybody ever ran across this
Old Jul 27, 2014 | 02:04 PM
enginebill's Avatar
The part of the exhaust that burns your eyes is un burnt hydrocarbons due to incomplete combustion. It is microscopic droplets of diesel fuel getting into your eyes. Probable cause is worn pump and injectors which don't atomize the fuel fully at idle which cause larger drops of fuel to come out of the injector. The larger drops will not burn at idle and pass right out the exhaust.
Old Jul 27, 2014 | 07:57 PM
gorms's Avatar
My truck doesn't seem to be as bad as it used to. Combination of new lift pump and regular power service additive seems to help a lot.
Old Jul 27, 2014 | 08:19 PM
Is there any way to tell which it could be injectors or pump thank you for the tip
Old Jul 28, 2014 | 09:33 AM
enginebill's Avatar
How many miles are on your engine? Unless the engine is hard to start or white smokes I wouldn't worry about it, just shut the engine off.
Old Jul 28, 2014 | 06:39 PM
200000 it starts fine. I just don't like it
1999 duallie
Jul 29, 2013 08:53 PM
Doj Dewd
Jan 26, 2011 03:13 PM
chrisgreenup
15
Dec 20, 2005 09:53 AM
Lary Ellis (Top)
Nov 28, 2003 10:55 PM
