running gear...
Old Dec 5, 2008 | 01:23 AM
DU.DP.'s Avatar
running gear...
about a week ago or 350 miles i had all new u-joints installed, except the driveline from the x-case to the front axle. i did all the work myself except having the u-joints pressed and carrier bearing replaced. i installed all new wheel bearing races, wheel bearings, seals, and one spindle. after driving around im still noticing a sort of grinding feeling but mostly on right hand turns going uphill, so it kind of tweaks the frame a little im guessing. could it just simply be bad u-joints in that drive shaft or a ring and pinion situation.
i checked those u-joints already and they felt good but the previous owner ran it in 4x4 all the time. (i dont think he knew it was engaged) it did some damage but already fixed. any input helps i just want to make sure i have a safe ride down the highway. thanks david!
Old Dec 5, 2008 | 01:25 AM
DU.DP.'s Avatar
oh and i have gone over everything to make sure its all snug and working properly. im just wondering if it is the drivesfahft because it should be spinning freely...
TIA david
Old Dec 5, 2008 | 11:08 AM
infidel's Avatar
Did you mark the driveline, trans case and differential so the u-joints went back in the same place?
If not the driveline could be out of phase. Wouldn't really call the result a grinding sound, more of a vibration.
Old Dec 5, 2008 | 07:32 PM
DU.DP.'s Avatar
i didnt do the driveline work work but the guy who did had marks and when it was laying flat it all looked in line. but just today i got home and my hubs were a little warm not like running in 4x4 warm but not normal. i checked the front drivlines it was disengaged im hoping everything went ok on the instal...
black&blue
Feb 18, 2009 08:32 PM
rsawmill
May 10, 2007 10:59 PM
wrangler04
15
Apr 16, 2007 01:43 PM
cap
13
Jan 19, 2004 08:23 AM
Hummin Cummins
Dec 25, 2002 12:29 AM
