replacing oil pan
Old Apr 28, 2005 | 03:27 PM
Txwelder's Avatar
replacing oil pan
anyone done this on a 4X4 and have some tips on doing it? Friend of mine needs to replace his because it is cracked around the drain plug. He already bought a new pan from Dodge just want to know if there are any tricks to doing it easier or possibly anything that could be damaged when doing this. Thanks
Old Apr 28, 2005 | 04:28 PM
smokindog's Avatar
Read the service manual. Also perform a search here. It came up a while ago and there were varying opinions on the procedure.
The book states that on a 4x4 you need to drop the transmission and transfer case to allow the pan to slide back and out. Good luck and have fun!
Old Apr 28, 2005 | 06:02 PM
Dr. Evil's Avatar
Dont quote me on this, cause I have yet to do it, but Ive read that you have to loosen the motor mounts anduse an engine crane to lift the engine = you can then slide the pan out. Dropping the tranny seems like a lot of work.
Old Apr 28, 2005 | 08:55 PM
msing's Avatar
Remove fan, pull motor mount bolts lift or jack engine up like 4 in. pan should come out. that is how I got mine out.
Old Apr 28, 2005 | 08:56 PM
Txwelder's Avatar
Thanks for the input guys, I will let you know how it goes.
Old Apr 28, 2005 | 11:07 PM
Hemi Cat's Avatar
sometimes you need a little extra room to get the pan out, if you do loosen the cab mounts and jack up the cab so you can get the eng up another inch or so. I think you have to remove the oil sump after you drop the pan to get it out of the truck.
Trooperthorn
Jul 13, 2010 11:45 AM
Mike T.
Feb 28, 2010 09:21 PM
tex23455
Jul 25, 2007 02:31 AM
MrKen
Nov 23, 2006 03:19 PM
bostongsx
Sep 25, 2006 11:25 PM
