Replaced seals and still leaking
Old Feb 4, 2008 | 07:51 PM
jknowles4's Avatar
This past weekend I replaced the rear pinion seal and the transfer case seal going to the front driveshaft. Both are already leaking. What could be the problem. I thought I did everything right.
When I removed the driveshaft from the rear there was a lot of play in the yoke. Is this normal? When everything was bolted back up it was tight again. Is there any chance I got the wrong seals or could the seals have been bad?
Also, which transfer case and rearend do I have? It's a 96 auto. Any help or advice is appreciated.
Old Feb 4, 2008 | 11:46 PM
Tate's Avatar
Should be a D70 and a 241HD or 241DHD. I lost several seals in my D80 due to a plugged vent, so might want to check those out. Are there grooves worn into the yoke? Might need a speedi sleeve on the rear. Not sure if you can use a sleeve on a slip yoke though.
Old Feb 5, 2008 | 02:10 PM
kawi600's Avatar
No slop in the pinion bearing thats eating seals?
Old Feb 5, 2008 | 03:07 PM
Busboy's Avatar
My yolk had a very slight scratch from the factory that took out the seal. Right away it started weeping on and off. The dealer did nothing. I found the scratch when I changed out the seal. I just dressed it out with a fine stone and it,s been good since. I have to question WHY it was installed like that in the first place?
ramlovingvet
Feb 9, 2011 10:14 PM
joshua smith
May 15, 2007 05:38 PM
kevellis32
Mar 25, 2007 08:54 PM
burlhall
Aug 25, 2005 05:15 PM
greasy
Dec 12, 2004 10:24 PM
