Replace 47re for 48re
Old Mar 27, 2009 | 09:28 PM
Valv's Avatar
Is it possible to replace my 1997 47re with a newer 48re ? Or even better with a 68re ?
What would I need to change ?
Old Apr 4, 2009 | 10:48 AM
SkyHarborCowboy's Avatar
Seems like someone should know!
Joe
Old Apr 4, 2009 | 11:11 AM
Tobin's Avatar
You can just rebuild the 47RE to make it into a 48RE. Call Georend and he can build it or sell you the parts for it.
Old Apr 7, 2009 | 09:52 AM
dzlfarmboy's Avatar
Yes you can, you will need a different trans Neutral saftey switch and you'll need to switch the electronics between the two valve bodys
Old Apr 16, 2009 | 10:02 PM
rigsy340's Avatar
the 48 runs higher pressures and will set govenor voltage faults in your pcm, then the trans will go into limp in. build your 47 with 48 planetary gears and upgrade baskets and discs. install a shift kit to the minimum drilling specs and you'll be happy for the street. if you have acess to parts use 48 converter, pump and stator.
Old Apr 27, 2009 | 11:48 AM
gmctd's Avatar
Go to PATC website for info with pics on converting 47 to 48
Old Apr 27, 2009 | 12:08 PM
You gotta provide a link because unless you know what the PATC stands for how is anyone going to find it?
Joe
Old Apr 27, 2009 | 12:26 PM
annabelle's Avatar
All 48RE parts will fit into your 47RE core.
thehemikid
Feb 25, 2021 12:45 PM
brutustitan
May 23, 2011 12:12 AM
Munchies
Oct 19, 2006 06:09 AM
FireNhole
Dec 7, 2002 04:39 PM
