Remove Valves?
Old Aug 19, 2007 | 06:57 PM
97ramctd's Avatar
Remove Valves?
Well the head is off to the machine shop and i was going to get it fluxed or whatever it's called to check for cracks. Should i remove valves before I take it in? Also will i have to put new valve seals on it? (The lil rubber things under the springs?)
Old Aug 20, 2007 | 10:37 PM
dieseldemon's Avatar
Are you going to grind the valves yourself? If so remove them it will save you some money and yes replace the valve stem seals Cummins part # is 3921640 and the ex and in are the same now so you need 12.
RoadDiesel
Aug 7, 2012 06:06 PM
Dodgezilla
Jul 17, 2004 05:24 AM
dodgeman01
Mar 13, 2003 05:30 PM
1ST GEN.
Nov 25, 2002 10:26 PM
