Rear End Play
Old Jun 7, 2004 | 08:29 AM
mysterync's Avatar
Rear End Play
Hey Guys,
I have got a buddy with a 3500 that seems to be getting worse and worse with play in the rearend. Its almost hard to drive without bucking. we pulled the plug, and besides some real fine shavings , there was just one small thin piece. Any idea on how much work or how much this will be? What usually goes with one of these rear ends or what else will cause this!
Thanks
Old Jun 7, 2004 | 12:26 PM
BBWD's Avatar
Re: Rear End Play
Originally posted by mysterync
Hey Guys,
Thanks
Had a similar problem with mine. Rear end noise kept getting louder and louder. Finally started leaking at the drive shaft seal. Turns out it was the pinion bearing. Had "in-and-out" play when we dropped the drive shaft to replace the seal. $700-$900 repair. Take it to a good shop who regularly does this kind of work as shimming to get the clearances correct is a critical part of the re-assembly process after replacing the bearings. A good shop will get this right the first time.
John (DH)
doorguy
Jun 8, 2007 06:19 AM
lews930
Oct 8, 2006 08:30 PM
blue dog
Apr 15, 2004 11:14 PM
hellotbone
Aug 5, 2003 11:18 AM
figure_9_pro
Apr 6, 2003 11:42 PM
