play in rear end
Old Oct 2, 2006 | 01:41 PM
lews930's Avatar
play in rear end
Let me see if I can explain this. When I turn the rear wheels(while jacked off the ground of course), I can turn the wheels probably 1-2 inches (maybe more, I didnt measure it) before the drive shaft begins to turn. Any idea as to what has caused this and how do I fix it before It costs more money?
the truck has 240K miles, automatic, 2500
any help greatlY appreciated
lewis
Old Oct 3, 2006 | 06:06 PM
Brendan's Avatar
I seem to have a similar problem, I notice it in reverse the most it makes a "clunking" sound with tap the throttle. To me it sounds like there is some play in the gears but that's about as far as I can go with it.
Old Oct 3, 2006 | 06:33 PM
DuallyMan's Avatar
I have the exact or what seems to be the same problem, no one has been able to help me so far.
Chris
Old Oct 3, 2006 | 07:10 PM
Teddy Bear's Avatar
You might want to check your ujoints and make sure they are good and tight. I had a 94 3500 and by the way it felt and sounded when i put it in reverse, i wouldve swore the rear end was shot. When we pulled my tranny we of course had to pull out the driveshaft. The rear most ujoint was completely shot. Not even 1 needle bearing in the whole thing Come to find out, the rear end was actually pretty tight with the new ujoint
Old Oct 3, 2006 | 08:28 PM
Common's Avatar
Guys, don't worry about it, its pretty normal for higher mileage trucks...
But check those U-joints to be sure...
Old Oct 8, 2006 | 08:30 PM
lews930's Avatar
ok,thanks
lewis
doorguy
Jun 8, 2007 06:19 AM
mysterync
Jun 7, 2004 12:26 PM
blue dog
Apr 15, 2004 11:14 PM
hellotbone
Aug 5, 2003 11:18 AM
figure_9_pro
Apr 6, 2003 11:42 PM
