Question On Fuel Transfer Pump
Old May 25, 2006 | 06:52 AM
RODGERDODGER01's Avatar
All of a sudden,yesterday jumped in the truck and wouldn't start, started fine before. So I primed the bulb on the transfer pump and at first it was easy than you could feel the pressure of fuel in the lines. Got in the truck and it started. Runs good but now I have a leak at the transfer pump. If I shut the truck off and re-start right away ,it cranks more than usual and hesitates but ends up starting. Where should I begin to troubleshoot before I go out and buy a new pump. Thanks
Old May 25, 2006 | 09:21 AM
Checked again this morning and its not the transfer pump leaking ,it's the return line above it. So could that be the problem of hard starting, also noticed that if I press a bit on the fuel pedal while cranking it starts right away. Before it started easy without pressing the pedal. Would it all be related to the leaking return line ?
Old May 25, 2006 | 01:45 PM
turbo thom's Avatar
If it's the truck in your sig, check the SD solenoid or the relay. Also the pressing of the accelerator sounds to me like the idle has dropped. The correct RPM is critical to starting.
..Preston..
Old May 25, 2006 | 06:27 PM
infidel's Avatar
Any fuel leak will allow air into the system when the engine isn't running and will cause hard starting.
Old May 26, 2006 | 08:34 PM
GAmes's Avatar
Have you ever replaced those two fuel lines?? They are famous for deteriorating and leaking, usually sucking air. Get some good marine hose and plan for about 2 hrs of cussing. Oh, they are two diff sizes, 5/16 and 3/8. If you get two ft of each you'll have plenty.
Old May 27, 2006 | 10:40 AM
infidel's Avatar
It's not good but normal for the solenoid to start smoking if you apply power to the lift up coil for more than about 15 seconds.
The only times I've seen solenoids go bad is when the starter contacts stick in effect applying power to the lift up coil for more than 15 seconds.
Old May 27, 2006 | 11:32 AM
arroyojim's Avatar
hey guys,
i was planning on replacing my fuel lines and they seem to be closer to 3 or more feet long from where the metal lines end up to the upper ends. not sure why this is. i'm wondering if my system was modified somehow since it is lifted?
Old May 28, 2006 | 04:26 PM
Thanks everyone for your help, found the leak, theres a 7" long 5/16 fuel hose that runs between two steel lines, underneath the intake kind of in between fuel filter housing and engine block . Anyhow I removed it and its cracked pretty good. Thats what was leaking, and as for the no start, SD solenoid is toast . Keeps blowing fuse when I turn key on, if I un plug harness at the Solenoid fuse is ok. Will look for a less expensive alternate to the $200.00 solenoid, but for now it's manual operation........thanks again
Ahousat Diesel
22
Jan 12, 2014 12:05 PM
derceg
Dec 23, 2009 07:24 PM
csramsey640
Jul 6, 2006 04:44 PM
8mpg
May 22, 2006 01:35 PM
