pump timming
Old Feb 22, 2008 | 04:29 AM
kyle_truck_pull's Avatar
Exclamation pump timming
i just need to know if there is a way to get the pump its self in time without the timming lock pin. the pin is missing from the pump and i didnt know if you can look in there to see if it is where it needs to be before i put it on the truck. thanks
Old Feb 22, 2008 | 10:05 AM
patdaly's Avatar
The book shows a visible slot, perhaps someone knows the dimension of the stock timing pin, you could use a suitable sized drill bit for a temporary pin.
Old Feb 22, 2008 | 10:07 AM
Mcmopar's Avatar
Yes, you can pull the number 1 injector and find TDC with a dial indicator, just be SURE you are on the firing stroke, but withy a gauge on the lift pump cam you will know.
Old Feb 22, 2008 | 05:33 PM
Tate's Avatar
Do you have a mirror? You can pull the plug out of the side of the pump and just look for the little arm to swing around. That will be the stock timing.
Old Feb 22, 2008 | 07:38 PM
Mcmopar's Avatar
What? Please explain
Old Feb 22, 2008 | 08:02 PM
logskidder's Avatar
If the "little arm" comes around to the center of the hole and the engine is at TDC this would be stock timing for that engine. The timing pins on these engines are not the best things to go by, however they can give you some idea. Also this can all be changed by a pump shop, they can set up the pump for more/less timing when the "little arm" is centered and the engine is at TDC ......hope this helps
Old Feb 23, 2008 | 08:33 AM
Mcmopar's Avatar
How do you know if you have slipped the gear? There would be no relation to TDC unless you check that too.
Old Feb 23, 2008 | 04:28 PM
Tate's Avatar
You always have to check TDC. If you're not at TDC, lift numbers aren't going to give you what you want.
Old Feb 23, 2008 | 07:44 PM
Mcmopar's Avatar
yes, I agree--so then what does the "arm" location mean? Nothing? It won't tell you jack if the truck has been changed at all.
Old Feb 23, 2008 | 09:16 PM
logskidder's Avatar
This is just how Cummins wants you to install a stock pump on a stock engine, I think that what the orig poster wanted to know.
Old Feb 24, 2008 | 01:07 AM
Tate's Avatar
It will time it to where the pump rebuilder wanted it set to. Set engine at TDC, set the pump so the arm is in center of the hole, lock it up. Thats how you'd do it if you don't have the dial setup.
Old Feb 24, 2008 | 09:01 PM
Mcmopar's Avatar
Gotcha
, thanks
Roger Arceneaux
Oct 8, 2013 06:01 PM
kyle_truck_pull
Jul 16, 2009 11:40 PM
wvopowered
Mar 9, 2008 05:13 PM
adidasman23
Feb 7, 2007 11:34 AM
