Pump Sprocket Nut Size (timing)
Old Oct 30, 2003 | 08:32 AM
kd460's Avatar
Will be doing KDP over the weekend, decided at last minute to check timing. In case it's off, does anybody know what size the nut is on the pump sprocket??
Any timing tips??? I will be using the dial gauge on the #1 delivery valve method. I don't have the delivery valve socket yet, I just picked up a magnet base and gauge, probably find TDC this eve and mark the balancer. Thanks, Kevin
Old Oct 30, 2003 | 11:15 AM
Don M's Avatar
DTR Advertiser
Re:Pump Sprocket Nut Size (timing)
I use a 30MM...works fine.
Old Nov 1, 2003 | 07:32 PM
kd460's Avatar
Thanks for the info, sorry I did not thank you sooner. Now all I got to do is find time to adjust the timing. It will be my first time and I am skeeerd!! Kevin
Old Nov 2, 2003 | 06:13 PM
Jim Fulmer's Avatar
After you've done it several times it's a piece of cake....a 1 3/16" socket will work too but I've got a 30mm.
Jim
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
Jesse917
0
May 13, 2005 03:14 PM
Paul Winey
Nov 1, 2004 12:08 PM
