Pump Leaking
Old Sep 26, 2006 | 10:57 AM
RZinKY's Avatar
Pump Leaking
My fuel system has lost its prime, I started to use the manual pump and noticed that fuel is leaking from ether the manual or lift pump. has any one had this problem before.
Old Sep 26, 2006 | 11:47 AM
schoust's Avatar
I would clime under there and get a real good look,most of my lines were weeping and I had a real mess that is until I decided to do all of them over...
Old Sep 26, 2006 | 01:13 PM
waldersha's Avatar
I actually have the same problem that you have. The advice given to me was that the lift pump (where you are pumping) has an o ring that gets bad and will allow the leak. The O ring is replaceable, but according to the posts I read easier to replace off the truck, so most replace the whole lift pump (about $150) and keep the other pump as a backup.
If I loosen the bolt on top of the fuel filter, mine doesn't leak. I guess the pressure will build up and get past the o-ring if you don't give the air someplace to go.
Old Sep 26, 2006 | 08:50 PM
arroyojim's Avatar
on mine it was the little elbow-tube between the prefilter/heater and the lp.
Buc4x
Apr 7, 2013 04:22 AM
jesussaves
Jun 28, 2012 01:36 PM
lilsuzuki4x4
Sep 1, 2011 01:50 AM
jared thompson
14
May 10, 2011 12:23 AM
christinyou
Mar 14, 2003 03:43 PM
