Power steering pump question.
A few months ago, I posted an issue I was having with my '96. When I made a low speed turn, (pulling out of a parking lot, or when parking), I had a wobble in the front end while making the turn, as well as when straightening the wheel. Forward or reverse, it doesn't seem to matter. Sometimes it is hardly noticeable, sometimes the whole truck will shake. I took it to an alignment shop, rotated the tires, and generally looked things over. I found nothing that could have caused the problem. It got better, and I thought maybe it was cold weather related, but it's back. It feels like the PS pump is coming and going, but I have no leaks, or noises coming from the pump. It almost HAS to be in the steering, so my question is, how hard is it to change the pump? I see that it's attached to the vacuum pump, and I don't want to start on something that requires tools I don't have. Thanks for any ideas you guys may have.
Thanks, that's a good idea. I had a bad caliper on a car years ago that made it pull like crazy to the left when the brakes were applied, so it can effect the steering. I'll have to take a look!
I spoke with a local alignment shop. A friend is a mechanic there, and offered to take a look at it after hours. My cousin runs a shop that's more of a brake, tuneup, electrical shop. He chased a similar issue all over a customers truck, (also a Dodge), and finally cured it with a bottle of Lucas power steering leak additive. Being as lazy as I am cheap, I tried a bottle. I pulled 12 oz of the old fluid out, and put the Lucas in. It seems to be working, although I haven't driven but about 30 miles since I installed it. The old stuff was really thin, so maybe it is the fluid. Once I'm back in it everyday, I'll know for sure. Thanks for the replies and ideas.
DodgeCowboy
Aug 28, 2006 08:57 PM
amartinson
0
May 4, 2003 01:55 PM
