p7100 pump settings
Old Nov 22, 2009 | 07:10 PM
Outlaw Diesel's Avatar
p7100 pump settings
Ive got a truck that was takin to a shop and had the pump messed with. i believe it was adjusted way out of its parameters and it knocks and misses at high rpm's loaded and unloaded. and is now hard to start. I need to find out all of the stock settings so i can fix this screw up.
Old Nov 23, 2009 | 01:21 PM
BigErksG2's Avatar
What lift pump you running? Could be not enough fuel getting to the pump, air in the lines, timing... If the pump stayed on the truck I doubt they could do much more than plate, afc, timing, and maybe turn the barrels. Might have streched the overflow valve spring and put too much stress on your lift pump if its the stocker. There will be a ticking heard from the front driver side wheel well if your stock lift pump is on its way out.
Ask the shop to write down everything they did so you can go back and find out what went wrong.
Old Nov 24, 2009 | 09:09 PM
i didnt hear any ticking or any thing abnormal. the guy dont know where the shop is or number or anything. im just trying to get this thing back running blindfolded. I have thought about air in the lines ive got a sight glass on its way so i can check it while its running. What really gets me is that it doesnt do it all of the time and when it does screw up its when its ran a little while
Old Nov 24, 2009 | 09:14 PM
G1625S's Avatar
So it runs fine sometimes, but not others? Any smoke? What color?
Old Nov 24, 2009 | 10:17 PM
Tate's Avatar
Check where the timing is at. Where is the idle?
Old Nov 25, 2009 | 11:38 AM
infidel's Avatar
My bet is a dolt who didn't know what he was doing tried adjusting the timing and got it way off.
Have someone who knows what they're doing set it to 15-16.
This isn't stock but will make the engine run better and get better mpgs.
Old Nov 25, 2009 | 02:05 PM
Lil Dog's Avatar
I'm with Bill and Tate, sounds like the timing is way too advanced.
Old Nov 27, 2009 | 11:58 PM
I messed with it today and drove it around. it only does it after it warms up. i put the sight glass in the fuel line and didnt see any air. im gonna try fuel pressure next and go from there.
Old Nov 28, 2009 | 10:33 AM
Yellow Yota's Avatar
Or, or, or......., You might want to get the timing checked! Just a suggestion.
Fuel pressure is important, too. But I think it would be more of a lack of power than a runs like crap. At least 'till it got way bad.
Old Nov 30, 2009 | 10:28 PM
How do you check and adjust timing on these things i know a lot about the newer cummins but havent mess with the 12 valves that much.
Old Dec 1, 2009 | 01:09 AM
Tate's Avatar
Need a timing light with pulse adapter, or a timing kit. The former is faster and easier, but more expensive to buy.
Old Dec 1, 2009 | 10:08 AM
infidel's Avatar
Instructions> http://dodgeram.info/tsb/1994/18-10-94a.htm
but you will need about $200 of special tools. For most people it's cheaper to pay someone to do it.
Old Dec 1, 2009 | 10:42 PM
It aint no problem doin it now since ive got the instructions I used to work on stuff like this at caterpillar but this is my first p7100
Old Dec 19, 2009 | 02:57 PM
Checked the timing and it is dead on 13.5 degrees I did find a pinched off boost line goin to the pump tho. Possible over boost? im gonna fix that problem and check fuel pressure.
td3620
May 6, 2011 01:29 PM
masonic-dodge
21
Dec 3, 2005 01:10 PM
mr T
0
Feb 5, 2005 10:35 PM
hvanflee
14
Oct 27, 2003 12:21 AM
jimrob
Feb 27, 2003 12:33 PM
