P-Pump died
Old Jul 19, 2007 | 10:07 AM
ckt_santiago's Avatar
Unhappy P-Pump died
Well fellas, to make a long story short, my pump has at least three scored barrels and I don't have $1600 for a new pump or even $725 for a rebuilt... No way to work now either means I'm pretty much screwed. Which is the worst part because as a disabled veteran jobs in my area are pretty hard to come by and so I am pretty much at a loss right now. Basically, all I can do is rant and hope to god that I stumble on one heck of a deal
Old Jul 19, 2007 | 03:44 PM
Hayseed's Avatar
Sounds like a good time to whip out the plastic. Man's gotta work!!
Old Jul 19, 2007 | 03:49 PM
Man I wish it was that simple... Don't have enough room on either of my cards and so that pretty much leaves me with selling my pulling tractor
I have found a 250hp pump off of an 8.3 that was in a garbage truck for $500. I know the shafts are the same and the linkage is transferable, but I just hope that the oiling is the same. But, it is used and that makes it a crap shoot since there is no warranty
Old Jul 19, 2007 | 04:57 PM
halfpint23's Avatar
ebay seller jeepntoy was just selling off a load of parts off a 94 ctd, he seems to be decent type - maybe he's got a pump?
second choice, look here -
http://www.pensacolafuel.com/index.p...ategory_id=193
price is right and they have a good rep. If you can squeeze it out, maybe...
Best of luck,
Old Jul 19, 2007 | 05:32 PM
logskidder's Avatar
The 8.3 oiling is not the same......nothing a pump shop can't fix though.
Old Jul 19, 2007 | 06:14 PM
You know, I had been told that before and knew it would have to be addressed... But, just out of curiosity, what is the difference? size of the fittings, placement of the oiling lines?
Old Jul 19, 2007 | 06:46 PM
clutch1's Avatar
youll regret selling your tractor, try not to. if your gonna pay $500 for the used 8.3 pump that has no warranty by the time you get it fabricated, installed, and everything right you might be close to the $725 for a rebuilt. hope you get everything squared away, good luck.
Old Jul 19, 2007 | 11:15 PM
Originally Posted by clutch1
you'll regret selling your tractor, try not to. if your gonna pay $500 for the used 8.3 pump that has no warranty by the time you get it fabricated, installed, and everything right you might be close to the $725 for a rebuilt. hope you get everything squared away, good luck.
Well, so long as it is only location of oil in/out and fittings then I will be fine. We have all the proper flaring and bending tools to custom fab up the oil lines should I need that. Also, no worries about overflow valves or anything of the like as I have a fuel pressure regulator that is simply hooked into the return side of the fuel system. Rustyshakleford found me the same pump that has recently been gone through by cummins. Also, called to double check on the local pump and it would at least have a 30 day warranty that would even cover the engine should the pump cause any damage.
Also, my dad has first dibs on my tractor and I need the money for other things too, this just broke the camel's back...
Old Jul 19, 2007 | 11:58 PM
RAMRODD's Avatar
Where are you getting the price for the pump rebuild?? Go directly to a diesel injection shop. I have had several injection pumps rebuilt under 500.
Old Jul 20, 2007 | 06:52 AM
Really now... Well we have business accounts with all the local shops and they all say $1600 to rebuild mine. What kind of pumps have you had rebuilt for under $500? Where?
Old Jul 20, 2007 | 07:11 AM
clutch1's Avatar
some shops here rebuild them for a pretty good price, we use the same shop all the time for the equipment. ill see if i can get some numbers later cause im not at the shop today.
Old Jul 20, 2007 | 05:07 PM
RAMRODD's Avatar
How do you know you have scored barrels?? You can get a complete rebuild everyting but barrels for $475 Which is basicaly new seals internaly and going threw the governor and checking it on a test bench. That is what it cost me to get a p pump on a 8.3 cummins gone threw. If you need all new barrels you will be in that $1600 mark.
Tommy93w350
20
Nov 1, 2005 11:07 PM
FRANKV569
Mar 9, 2005 04:25 PM
AlbertaBear
20
May 12, 2004 09:04 PM
midwestdually
Feb 25, 2003 07:43 AM
Copenhagenjunkie
Nov 29, 2002 09:10 AM
