P pump
Old Aug 4, 2011 | 06:20 PM
samboats's Avatar
P pump
One quick question. Will the p pump from a 5.9 fit an 8.3 engine?
Thanks for any info.
Old Aug 4, 2011 | 08:59 PM
cj360trider's Avatar
yes it will but the performance will probably be different. a 6bt doesnt have the fuel needs of the 6ct.
Old Aug 10, 2011 | 06:42 PM
jstone44720's Avatar
There is an interesting question though : will the internals from an 8.3 pump fit in a 5.9 pump, and give more fuel or a different type of delivery?
Old Aug 10, 2011 | 09:50 PM
a p pump is a p pump and a ISC or 6ct wud have more of a 215 pump factory as opposed to most 6bt's having a 160 or 180. as we all know the p pump is very powerful and the most sought after pump for our engines it wudnt have any trouble melting an 8.3 to the ground if your foot was heavy enuf
Old Aug 11, 2011 | 12:24 AM
Tate's Avatar
False. A lot of equipment uses P3000 pumps. Also, many industrial/commercial apps use 11mm plungers instead of 12mm plungers in the dodge applications. Cam's will also be different. Just because it is on a bigger engine doesn't mean its a bigger pump.
Old Aug 11, 2011 | 09:54 PM
We use P7100s......is it all the same?
Old Aug 12, 2011 | 02:07 AM
Tate's Avatar
No, its not all the same.
Old Aug 16, 2011 | 10:47 PM
ah ok i see....sry i read it as you saying a P3000 was the same as a p7100 my bad. so wud a p3000 be a different model in the same series of pumps?
powerwagon440
May 25, 2003 02:31 PM
Puke
May 22, 2003 12:18 AM
amartinson
0
May 4, 2003 01:55 PM
TPilaske
16
Nov 22, 2002 08:15 PM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
