p-7100 questions
p-7100 questions
I have the p-7100 pump on my motorhome and was going to set the high and low idle stop screws. Fos the high idle screw is it the one under the pump that has a 10 milimeter lock-nut and a screw with a small hole in it? On the low idle screw all i see is a micro-switch that hits the stop, so how do i change idle speed with this set up? Thanks,Rod
