overflow valve part number
2 417 413 093 000 = over flow valve (old #) *may not need the 000 on the end of the p/n#
2 417 413 101 000 = over flow valve (new #) *may not need the 000 on the end of the p/n#
I've got a fixation with Bosch #'s for our motors
Having two of Marty's OF valves go bad indicates to me that something is wrong with your injection pump causing it develop high back pressure. I sort of doubt a Bosch valve will last much longer until you address the real source of the problem.
when the lil valve goes bad what happens to it?? can u see the damage?? or if i take mine off will it look the same as a new one?? how do u tell for damage once its off? (pics are always welcome
