oops!!! help
Old May 11, 2011 | 09:00 AM
isissound's Avatar
Unhappy oops!!! help
hey guys, So last weekend I pulled my head off my 96 dodge 12v well I guess everything was not disconnected broke one sensor on the back right side of the block which I believe to be my water temp sensor??? I also broke a connector that was on a pigtail on the front of the block any idea what this is so I can order a new one the connector is round with 3 pins in it???
Old May 11, 2011 | 09:48 AM
infidel's Avatar
Sounds like the connector to the engine speed sensor, sometimes mistakenly called the crank position sensor.
Old May 11, 2011 | 10:12 AM
isissound's Avatar
ok sooo... do i order a new engine speed sensor??? where should the wire go so that i can varify this???
Old May 11, 2011 | 08:06 PM
isissound's Avatar
any one know where the engine speed sensor is so i can locate it???
Old May 11, 2011 | 08:18 PM
Lil Dog's Avatar
This picture doesn't show the ESS specifically but has many of the others on it
If you go to http://www.dodgeram.org and look under the diesel section, there is lots of good info on there.
The ESS is located on the front of the engine near the harmonic balancer. The wiring harness runs to it branching from the main harness that feeds the alternator and across the front to the injector pump and back along the block to the fire wall.
Old May 12, 2011 | 10:38 AM
infidel's Avatar
harmonic balancer = lower engine pulley
Jeepman71
Oct 26, 2012 08:24 AM
slapshotmike24
Jul 22, 2009 09:32 PM
4doogie
Dec 15, 2008 12:37 PM
BPD239
Oct 26, 2002 08:53 PM
