oil light flickers
oil light flickers
you guys were so helpful the last time i worked on my brothers 97 one ton 4x4 stick ctd that i am back. he just did a round trip from central ore. to redding california hauling a bunch of range bull to a sell. all the fixes on trans. clutch, cooling ,front axle seals, i worked on here a few months ago went great and he says thanks. but he did notice his idiot lite on the dash for oil is flickering on and off. during the day it is so dim can't see it but at nite he can. regular oil gauge is rock solid and checking oil all is great. seams like changing throttle position or speed makes it go on and off. i am thinking wire loom is rubbing on firewall or engine causing a intermittent ground. i didn't know it had a oil light. any one have this problem ? again we says thanks for the info. i did a search and saw alot about the gauge no mention of a lite.
Only one sender. After the signal goes to the PCM it divides it into two signals, one for the gauge, the other for the light. The short for the light probably reacts to cause attention faster than the gauge needle moves.
Sender is closer to the power steering pump than the fuel pump.
BKR
Feb 14, 2013 06:22 PM
aggiebowhunter
Oct 5, 2009 10:12 PM
babyjoe
Jun 6, 2008 09:53 PM
auSS/Tin
Jan 18, 2007 09:09 PM
