oil leak
Look closely and feel around under your injector pump for oil. If you don't see any there, check the under side of the coupler adapter between the vacuum pump and power steering pump. If you find oil there the seals probably leaking. It's repairable for a lot less that replacement. Do some searches on this site for 'vacuum pump' for more info.
I also got an oil leak, its tranny fluid thats leaking, well a red fluid so im guessing its tranny fluid, the farthest point foward that its leaking is right behind the engine oil pan, a gasket mabye? any ideas?
george7941
Nov 28, 2009 09:28 PM
Iron City
Jun 12, 2006 02:37 PM
donhov
26
Jan 6, 2006 07:29 PM
PCarnathan
Aug 15, 2005 09:59 AM
