Oil Fill Plug leaking
Old Apr 3, 2005 | 05:04 PM
R Walter's Avatar
I replaced the old Mopar oil drain plug gasket with a new identical gasket from the Dodge dealer at the same time that I replaced the factory oil drain bolt/plug with a new one from Dodge also.
Can't get it to stop leaking from around the fill hole. I know the correct torque is 40 ft-lbs. I've gone a little tighter and it's still leaking.
What gives?
Old Apr 3, 2005 | 09:12 PM
Fueling around's Avatar
Sometimes you just turn it over (the gasket). Supposed to be universal, but I get much better seal with the full rubber side to the pan.
Old Apr 3, 2005 | 10:51 PM
torquefan's Avatar
Possibly, someone sometime has overtightened the drain plug and caved in the pan around the hole. On problem trucks, I have installed an O ring to the drain plug on top of the gasket. That seems to help these situations.
Old Apr 4, 2005 | 07:41 AM
Eskimo's Avatar
I put a hairline split in my fillplug after accidentally tightening it when I meant to loosen it.. ya positive it's coming from AROUND the hole?
Old Apr 4, 2005 | 10:10 AM
infidel's Avatar
Once the pan is distorted from overtightening the best way to deal with it is to replace the plug with one of the many drain valves available. Then you can clean the area up well and use silicon to make a good seal that you'll never have to break again.
PapaPerk
Nov 29, 2004 09:13 PM
kevlar
Aug 11, 2004 08:42 PM
Homestead
May 21, 2003 11:30 PM
Ruralmedic
May 13, 2003 08:00 PM
latitud_rt
Oct 23, 2002 10:31 AM
