NV4500 Speedometer drive???
Old Aug 11, 2006 | 07:34 AM
JimmieD's Avatar
As some of you know I'm doing a Cummins swap into a '67 Dodge Town Wagon. Got a NV4500 off of E-bay at a good price. It was refurbed by a tranny shop and is in good shape but I find that it's missing the speedo gear or whatever it is that goes in the tailshaft for speedo. All it has is the vacant hole! What goes in there and what can I expect to pay for one used? Any clues??! Thanks for advice.....
Oh, it's supposedly a '96 2WD that uses mechanical speedo.
Old Aug 11, 2006 | 06:47 PM
A '96 would have an electronic speedo. I'm gonna move this over to the 2nd gen forum, since they have more experience with NV4500's.
Old Aug 11, 2006 | 08:59 PM
JimmieD's Avatar
Thanks, I appreciate it!
Old Aug 11, 2006 | 09:04 PM
GAmes's Avatar
It has a gear and a sensor that is actually a small generator (for lack of a better term). The faster you go the more current it sends to the speedo which has a small electric motor driving the odometer and the needle. I replaced mine and I believe the two parts came to around $100, could have been less. I'm not sure if you can adapt them to an after market speedo.
Old Aug 11, 2006 | 09:29 PM
JimmieD's Avatar
Thanks for the tips! I double-checked and the tranny is a '97 so it's definitely electronic speedo. I checked out the AutoMeter website but couldn't make heads or tails from their info. Something about a Hall effect sensor on their elec. speedos but no further info that I could find. Called a vendor for Autometer and all I got was maybe and could be and zip for brains. I must use an aftermarket speedo and don't want to buy any parts I don't need. Thanks again....
Old Aug 12, 2006 | 12:59 PM
gmctd's Avatar
+5v supply, probably Hall effect, puts out a 5v pulse, 8 pulses per rotation, factored by number of teeth on output shaft gear, final drive ratio and tire dia for pulses per mile
Old Aug 12, 2006 | 09:08 PM
JimmieD's Avatar
And thanks again! Looks like I need to talk to the AutoMeter folks as I'm probably going to use their gauges and speedo. A friend gave me 3 of their gauges brand new, oil pressure, volts & water temp, so just gotta fill out the set. Still at least $400 even with the gift! Yipes!
Old Aug 12, 2006 | 11:01 PM
gmctd's Avatar
Dodge\Mistubishi speedo needs ~41 pulses for 20mph, ~112 for 55 - it's linear
Old Aug 13, 2006 | 08:00 AM
JimmieD's Avatar
Glad they're doing the math. I get confused even figuring out the mile posts on the highway once it gets past 3....
Old Aug 13, 2006 | 09:19 AM
gmctd's Avatar
Compare required p\m to requirements for speedo of your choice
Old Aug 13, 2006 | 10:08 AM
JimmieD's Avatar
Ahh, okay. Pulses per mile compared to speedo? I saw some mention of 16 pulse regarding AutoMeter so have to go back and check that. Thanks again.
RRRoger
Sep 2, 2011 10:19 AM
SilverSootXpres
Mar 23, 2010 07:18 PM
ejeep01@gmail.c
Feb 18, 2009 09:18 PM
Geebeer
Jan 24, 2008 08:01 AM
jive55
Feb 12, 2005 10:40 PM
