nv4500 leaks
Old Nov 29, 2008 | 12:13 PM
cminzey's Avatar
nv4500 leaks
Ok I have a 94 3/4 ton 4x4 the trany is leaking between the transfer case and the trany is this an easy fix by taking the transfer case off the trany and replacing the seal in the trany or is it deeper than that it is gear oil I think that is leaking, if it.s not gear oil does the case on the trasfer have to be opend to rplace that seal
Old Nov 29, 2008 | 01:07 PM
chariotdriver's Avatar
Not too bad
Fairly easy; just get a good 12 pt socket to take the bolts out.....they strip easy then it's a pita. There isn't a seal/gasket, just silicone. While you have it off you can check the 5th gear nut if it hasn't been fixed yet. You can tack-weld the one as it is (provided it isn't loose), or buy the updated nut and you will need the two special socket/wrenches to get it off. Less than 3 hours if you are semi-handy with tools. cd
Old Nov 29, 2008 | 01:36 PM
cminzey's Avatar
So if I am understanding this wright there is no seal between the transfer case and the trany just silicone no can I see the 5th fgear nut from the back of the trany as well I guess
Old Nov 29, 2008 | 04:13 PM
Once apart
When you slide/drop the transfer case off the back of the tranny (8 12-point bolts, 10mm I think) the 5th gear nut is the first/only nut on the tranny mainshaft that goes into the transfer case. The only thing sealing the transfer case to the tranny is a bead of silicone and some very flat surfaces. Make sure you support the tranny/engine before you drop the cross member, a good tranny jack is worth it's weight in gold and you can do the job yourself with one. cd
Old Nov 29, 2008 | 07:56 PM
cminzey's Avatar
thanks for the help so I need to buy the special tools for this job ?
Old Nov 30, 2008 | 02:43 AM
srv8800's Avatar
which side of the adapter is it leaking from? there is a seal that seals the input of the tcase against the adapter to keep the gear oil from mixing with the atf in the tcase. what drained from the tcase? make sure you fill the tranny with the right fluid.
Old Nov 30, 2008 | 04:46 PM
cminzey's Avatar
It's leaking on the trasfer case side of the adapter gear oil is what is leaking
Old Nov 30, 2008 | 06:08 PM
srv8800's Avatar
in that case, you need to replace the tranny output seal. pull the tcase and you'll be looking right at it. then reinstall the tcase with a thin layer of rtv.
Old Nov 30, 2008 | 07:23 PM
cminzey's Avatar
should I do the 5th gear nut fix as well
abchoppers
Jan 26, 2011 05:38 AM
SilverSootXpres
Mar 23, 2010 07:18 PM
Timinva
Sep 3, 2004 10:15 AM
Paws
Jan 21, 2003 10:11 PM
