NV4500 adapter?
Old Feb 8, 2010 | 05:11 PM
gorms's Avatar
NV4500 adapter?
Does anyone have a good source of an NV4500 bellhousing adapter? I'm swapping out the auto, and I'm trying to get every piece I can before the front seal on the auto finally lets go. It only really leaks when transmission temp is under 100 degrees or so farenheit. So far I've only got the gearbox (complete), clutch pedal assembly, and I've got a source on swapping the PCM for a reman. for a reasonable price. Still need the adapter, all parts of the clutch, main shaft for transfer case, and a clean garage.
Any other sources of needed parts or general info is GREATLY appreciated. I'm looking at an adapter on ebay that ends tonight, but I really hate fighting for something I really need if I don't have to...especially when it ends after my bedtime.
Thanks for any help!
Old Feb 8, 2010 | 05:26 PM
patdaly's Avatar
Adapter is the same, Auto to Stick.
Old Feb 8, 2010 | 05:31 PM
gorms's Avatar
Really? So NV4500 and 47RE bolt up the same? I was always under the assumption the plate that bolts to the block had to be swapped out.
Old Feb 8, 2010 | 09:06 PM
Tate's Avatar
If you are putting a NV4500 in a 1st gen, then that would be true. If its a 2nd gen, they all have the same adapter.
schamran
Jun 17, 2015 05:56 AM
dzl_damon
Dec 2, 2010 11:13 AM
SilverSootXpres
Mar 23, 2010 07:18 PM
roverhybrids
0
May 31, 2007 08:08 PM
