Nv4500
Old Oct 7, 2007 | 12:48 AM
smokin93's Avatar
Nv4500
Is there a difference between the chevy and the dodge Nv4500?
Old Oct 7, 2007 | 01:16 AM
displacedtexan's Avatar
There are a few, what are you trying to do?
Old Oct 7, 2007 | 01:51 AM
dieseldemon's Avatar
Yes the Dodge is a much heavier trans (stronger)
Old Oct 7, 2007 | 01:11 PM
smokin93's Avatar
I am trying to put it in my 93 auto, but if it's different I won't bother. Is the output shaft the same amount of splines? He says it's an HD, I don't know if that means anything. It's out of a 94 3/4 chevy 4X4 Diesel.
Old Oct 7, 2007 | 01:32 PM
Box5's Avatar
there different.
Old Oct 7, 2007 | 02:07 PM
lews930's Avatar
call Rockland Standard fear and let themtellyou they are different, 877-774-4327. These guys above may be right but I find it hard to believe that they would have the same tranny but different?
Old Oct 7, 2007 | 02:16 PM
kas83's Avatar
They are different, the Chevy has a lower first gear ratio for sure. The spline counts I'm not sure of, but I think the Chevy has fewer(coarse splined IIRC). The Chevy's never had the 5th gear jam nut problem. As far as strength, they are the same. It's the same components for the most part, so I can't see them being a whole lot weaker.
Old Oct 7, 2007 | 06:04 PM
Troutstrannysvc's Avatar
input shaft is differnt spline
SilverSootXpres
Mar 23, 2010 07:18 PM
BigBlock
Feb 11, 2003 05:41 PM
Cummnzpowr
Jan 8, 2003 10:03 PM
whiteknight
Dec 27, 2002 06:28 PM
Hummin Cummins
Dec 25, 2002 12:29 AM
