NP-205 in a 96 Ram
Old Dec 3, 2008 | 10:26 AM
74dart's Avatar
NP-205 in a 96 Ram
I checked Advance adapters and there is a kit to do this using a 205 from a Ford truck. Does anybody know which axel is the short axel on the CK pickups. I want to do this swap and run the twin stick shifter and am doing some reaserch on what it would take.
Old Dec 3, 2008 | 11:00 PM
srv8800's Avatar
what do you mean by short axle? i'd love to have a twin stick 205 in my tow rig. that's what i run in my 4x4. the low gear in a 241 is a little lower. i think it's around 2.71 and a 205 is 2:1. what is the plan for the rear driveshaft? a 1410 single joint shaft in the front would be nice.
Old Dec 4, 2008 | 05:48 AM
74dart's Avatar
The shorter axle determins if the xfer case is a left drop or right drop. You cant flip one over. The only leftdrop 205 is from 1968-1979 ford trucks. Lomax has a kit that comes with a new case and 3:1 lowrang gears but they only make it right drop with a chevy bolt pattern. When I get a few things paid off I might look at putting in a twin stick atlas II.
Old Dec 5, 2008 | 11:04 AM
srv8800's Avatar
i just call it driver or passenger drop. the fords are the only driver drop. just curious, why you want a tcase built for a crawler in your diesel? i can't remember the last time i needed to front dig my tow rig.
Old Dec 5, 2008 | 06:58 PM
74dart's Avatar
We have a couple hundred acers with 50% in woods and a creek crossing it. I would like to be able to traverse the entire property in my truck including crossing the creek. It is not a big or deep creek but it does have a few steep banks. I also have a 1954 M37 military dodge to use but I still would like to use the cummins. I am building a ranchhand style bumper and grill guard and headache rack to protect the stacks from tree limbs. I will probally just put an atlass II in it when I have the money.
Old Dec 6, 2008 | 02:12 AM
srv8800's Avatar
that $ would be much better spent on a set of lockers. unless you've been breaking stock tcases, the 241 isn't half bad. decent low range for a stock case.
that said, post up pics if and when you do it.
Old Dec 6, 2008 | 02:42 AM
Tate's Avatar
203/205 doubler would be cheaper than an atlas wouldn't it? And then you have the same low range, with a mid range as well.
Old Dec 6, 2008 | 03:37 PM
74dart's Avatar
That is true. Our 78 w300 dump truck has a stock 203 in it.
Old Dec 6, 2008 | 04:00 PM
1-5-3-6-2-4's Avatar
the 205 is actually 1.96:1 low range. you don't have to front dig only with a twin stick 205. the rear low 2wd is handy for backing trailers up too. I use 4low for backing trailers often just because with the stick its just nicer. if I had 2low I'd use that but I don't so 4low it is.
Old Dec 6, 2008 | 08:13 PM
74dart's Avatar
When I did the NV-4500 swap I used an Eaton shift **** and replumbed the switches to control the CAD. Flip the 2 switches one was and it locks the other it unlocks. When I pull I use 2 low to back because of the con-fe.
Attached Thumbnails NP-205 in a 96 Ram-p1010125.jpg   NP-205 in a 96 Ram-p1010126.jpg
Old Dec 14, 2008 | 09:15 PM
grover's Avatar
74dart thats a sweet shifter ever accidently shift while running down the road?
Old Dec 15, 2008 | 04:20 PM
74dart's Avatar
No not yet. It almost didnt fit I would not go into 2nd I had to redo my speaker box and shorten it by almost 2 inches.
G1625S
Feb 18, 2005 04:17 PM
jive55
Feb 12, 2005 10:40 PM
andyr354
Nov 17, 2004 03:04 PM
RHC
Nov 17, 2003 02:47 PM
antknee
Jul 3, 2003 01:06 PM
