No torque converter lockup
My TC lockup isn't working anymore. I have a manual switch, but it doesn't work with the man. switch or auto switch. When I use manual switch it sometimes kicks in when I am comming to a stop. Could trouble be with throttle positioning switch?
Thanks......
Thanks......
Manual switch should engage the lock-up when on the throttle in 3rd gear or O/D.
If not check the ground and connection point to the harness for corrosion or loose connections. If all good then the L/U solenoid may be bad.
From: Climax, MI (between battlecreek and kalamazoo)
the auto non lockup may be caused by the TPS but the manual switch should work in second gear and above. so i would say check your connections and make sure you have good a good ground to your manual switch and a resistor installed in the switch line if it is an RE unit.
Chris
Chris
Thanks for all the help....Got it done.
I drilled a hole in the TPS, and sprayed some WD40 in it and then drained it.
I drove the truck and discovered that it was worse then ever; I had also lost overdrive.
I called a friend who has a wrecking yard and has a lot of Dodge diesels, and bought another TSP for 50 bucks, and everything works like a charm.
93dieselZak
Jun 16, 2011 06:10 PM
tomh
Feb 14, 2005 08:26 PM
tractor-man
Oct 13, 2004 02:54 PM
Jambbii
Apr 27, 2004 02:31 PM
Jambbii
Oct 18, 2003 07:08 PM
