No Power
Old Jan 10, 2007 | 10:04 PM
Monkey 456's Avatar
No Power
I got a 1996 12 valve with 180.000 does not have any pulling power any more. I go on ant type of incline and it falls on it face. Any help would be great.
Old Jan 10, 2007 | 10:20 PM
Rare1's Avatar
What is the turbo boost accellerating up a hill?
Old Jan 10, 2007 | 10:23 PM
displacedtexan's Avatar
When did you last change the fuel filter?
Old Jan 11, 2007 | 11:37 AM
Monkey 456's Avatar
I dont have any gauges in the truck. The fuel filter was changed less than a 1000 miles ago. It still seams to run good. I noticed when the last time I drove the truck it smoked for about 5 min after of driving. It does this when it is really cold out. I think I have read some wear that it could be out of time.
Old Jan 11, 2007 | 10:03 PM
plow's Avatar
what color smoke?
Old Jan 11, 2007 | 10:47 PM
Monkey 456's Avatar
It's puffing blue. The truck is stock exept the k&n drop in and 4 inch cat back. I really like the truck and want to fix it.
Old Jan 12, 2007 | 12:39 AM
cumminsdriver635's Avatar
Probably needs a new overflow valve for one thing, and the timing set. Do a search for Marty Tompkins for the overflow valve.
Eric
Old Jan 13, 2007 | 07:45 AM
gmctd's Avatar
The diaphragm in the wastegate actuator - that small 'can' bolted to the side of the turbo - can rupture, which will bleed-off manifold pressure.
That causes the AFC diaphragm to run at atmospheric pressure, so you get no additional fuel, and no additional manifold pressure, and no additional fuel, and no add......well, you get my drift.
BTW - manifold pressure is what we affectionately term as - Boost.
So - no Boost = no fuel = no power.
Check the system out for leaks - manifold to AFC housing to wg actuator.
Old Jan 13, 2007 | 12:40 PM
Monkey 456's Avatar
Thank guys for the info. I will tryand check that out this weekend.
RAK GUY
Apr 5, 2003 10:28 PM
powerwagon440
Jan 20, 2003 08:50 PM
pwabbott
14
Dec 20, 2002 08:23 PM
Garz
Nov 17, 2002 02:02 PM
