No Grid Heaters
Old Dec 22, 2004 | 09:43 AM
BIG&BAD's Avatar
No Grid Heaters
hey guys
i have been noticing that my lights dont dim and my voltage gauge doenst move anymore
when i start my truck up cold
its used to do it all the time when it got to about 30 degrees
is there a fuse or relay for the grid heaters? what controls the gridheaters?
thanks for your time guys
i appreciate it
Bruce
Old Dec 22, 2004 | 10:34 AM
INJECTOR JACK's Avatar
Does the wait to start light come on?
Old Dec 22, 2004 | 10:54 AM
infidel's Avatar
Most common grid problem is the small trigger wires falling off the two relays almost under the driver's side battery. They just slip over a threaded post, a little squeeze with some pliers before putting them back on will tighten them up.
If you are plugging in the block heater for long enough the grids won't come on at all.
Old Dec 22, 2004 | 11:48 AM
berner's Avatar
The haynes manual does an excellent job of running a check through the whole grid heater system. I ended up replacing the solenoids. Only one was burnt, but DC only sells them in pairs. Go figure.
Old Dec 22, 2004 | 02:36 PM
farmer dave's Avatar
I had the same problem with my last truck. The grid heater relay was bad. I didn't know it until it was about -10 and truck hardly started. It is a easy fix.
Old Dec 22, 2004 | 06:31 PM
infidel's Avatar
Next time skip the dealer and buy a starter solenoid for an old Ford from any auto parts. Very heavy duty for under $10.
Old Dec 22, 2004 | 06:34 PM
doodah's Avatar
I think I need to know more infidel!lol how old of ford? starter solinoid?
Old Dec 22, 2004 | 07:13 PM
vtailflyer's Avatar
My 93 Aerostar has a real good starter solenoid that would work for the heaters...
wonder if my wife would mind
Old Dec 22, 2004 | 09:59 PM
BIG&BAD's Avatar
yes the lights comes on and stays on for about 30sec "i just tried to start it w/o pluging it in - no go
when i went hunting in nov it got down to about 30 and i could not turn it on without have to jump it to another battery then finally it turned over and came to life with a most impressive smoke show
im not sure what wrong with my truck cause i cant get it to turn on without a boost
im going to get my batterys checked, replace the cable that connects the batterys, get a starter solenoid for a 93 aerostar, and check under the drives side battery, and also rebuild my alternator
i just want to know that my truck will start when i really need it to
if you can help me out some more that be great
thanks for all the replys and help
Old Dec 22, 2004 | 10:09 PM
berner's Avatar
I should have said "relays" not solenoids. Under the drivers side battery. They come in pairs. Old Ford solenoids work for this application??
Old Dec 22, 2004 | 11:08 PM
I guess they would because they handle high current for a period of time so they should work. Sounds like you have battery trouble as well if you have to jump start it. I rebuilt my alt not long ago , it's no sweet if you can find the parts. Have you tested to see if you are getting power at the grid when the wait to start light is on? Also check your grounds as well a easy thing to over look.
Old Dec 23, 2004 | 05:14 AM
twoweeks1's Avatar
Injector jack where did you get the parts for your rebuild? how much were they. Mine sometimes surges in power and have always in the back of my mind thought the end is near. Thanks wayne
Old Dec 23, 2004 | 08:44 AM
kd460's Avatar
Don't want to speak for Injector jack, but heres a few sources:
http://www.fixinrams.com/index.html
http://www.fostertruck.com/dodge/default.htm
And if you need replacement, check these babies out:
http://www.mean-green.com/index.html
Good luck, Kevin
Old Dec 23, 2004 | 09:37 AM
Thats the 1st time I have looked at the Foster truck parts. They have some good stuff. I have used the heavy duty starter parts in my Dads 98 they work great, bought them from PDR though.
Old Dec 23, 2004 | 09:59 AM
infidel's Avatar
Yes they work excellent. For some reason when relays are rated for high amps they're sometimes called solenoids but what you want is in fact a relay. Ford used the exact same relay in every one of it's vehicles since 12 volts was introduced in the 50's until late in the '80s. They must have made billions of them, very easy and cheap to come by. If an auto parts guy doesn't know what a Ford starter relay is he might need help tying his shoes also.
The relays Foster truck sells are not rated high enough for the grids.
