New2 2ng gen
Old Jun 5, 2006 | 08:35 AM
ruquik's Avatar
New2 2ng gen
A good friend of mine picked up a 96 12v with 85K after i showed it to him. I am a first gen guy and know all of those free mods but I am totally unfamiliar with the P pump 12v's.
What are some of the easy/cheap mods we can do.
So far I have only removed the silencer ring.
Also for some reason if you "blap" the thottle at a stop the truck will (on occasion) just load up and stall. The only thing I could think was the fuel filter It is making us kinda nervous but the truck does have a warrenty.
Thanks Brad
Old Jun 6, 2006 | 06:58 PM
bmoeller's Avatar
Where is the idle speed set at? If it is too low, it can/will stall.
Gauges first, then free mods.
Slide stock cam plate forward
Slide AFC housing forward
Loosen up the AFC spring (turn top of wheel toward the engine)
Old Jun 6, 2006 | 07:03 PM
Abbynormal's Avatar
Also do a search here for Free GSK for the P Pump. It uses a washer to shim each of the governor springs and makes it act like a 3K GSK. Lets it pull to about 3200 RPM. Also bump that timing to 16*. It'll make a LOT of difference in the drivability as well as a 4" exhaust.
D-Roc
ABDTR #5
May 2, 2010 01:20 PM
learners_permit
Jul 9, 2007 06:08 PM
C&C Milo
15
Apr 16, 2007 10:08 AM
NHdodgeman
Feb 5, 2007 12:25 PM
apache
Oct 17, 2004 08:24 PM
