New member going from GMC HD to dodge
Old Nov 22, 2004 | 05:55 PM
Slowsupra's Avatar
I currently have a 02 GMC HD 2500. I want a 12 valve, 5-speed dodge. I know there are some problems with the 5-speed trans but which one are the best, what years and what probs do they have. I pull a heavy trailer with my gmc alot and I stiil want to be able to pull it from indianapolis to texas but I want to mod it. I have searched but no found the info I want. Any advise would help thanks.
Eric
Old Nov 22, 2004 | 06:00 PM
ride_a_hd's Avatar
Good site right here for the info you need, Eric. Use the search function and you can find enough information to keep you reading for hours! I'm a new owner of a 95 12v 5spd (no problems with tranny AT ALL) and love the truck!
Dave
Old Nov 22, 2004 | 06:25 PM
Rganser's Avatar
Dave
Ditto
Old Nov 22, 2004 | 09:40 PM
4doogie's Avatar
the best year would be the 98- 12 5 speed, this is cause you can open the back door and it comes with the bigger fuel pump, 215hp instead of the 160hp
Old Nov 23, 2004 | 07:04 AM
gunracer1's Avatar
the 96 to 98 5 speed 12valves have the big 215 pump, but any 94 to 98 can be modded pretty easy to get 1k torque. the nv4500 is a weak link in these trucks. i have said to he!! with it and purchased a 6 speed to put the 4500 out of it's misery for my truck.
Old Nov 23, 2004 | 07:11 AM
SHARPMACHINE's Avatar
As said before, all 12 valves are easilly modified. Do the real shopping on getting a truck that you will like after the mods are done, as I think that is harder than getting the big horsepower.
welcome aboard!!
just my .002
Old Nov 23, 2004 | 07:16 AM
walexa's Avatar
slowsupra,
I agree with the others 96-98. I believe the 98 is the first year that you could get the short bed with the extended cab, plus the back doors. Good luck in your search.
The only real problem with the 5 speed is that 5th gear nut can back off, but there is more than one place that sells a fix for that. From what I have read on this forum, the nut normally backs off due to lugging in 5th below 1600 rpm. Anyway, I have read that the nv4500 (5 speed tranny) can realiably handle up to 1500 ft lbs of torque....
Old Nov 23, 2004 | 08:25 AM
apache's Avatar
The trans can be corrected by installing a fully splined shaft. I think the part is around $200. as mentioned 94 to 98.5 are most desirable. the p7100 injector pumps are tops, no electronic BS like later models.
Old Nov 23, 2004 | 06:51 PM
Slowsupra's Avatar
Thanks for the info guys..
Eric
Old Nov 25, 2004 | 10:01 AM
Slowsupra's Avatar
I see two different posts about what years have the big pump, how can you tell when you look at the truck?
Old Nov 25, 2004 | 10:47 AM
G1625S's Avatar
94-95=160 pump
96-98=215 pump
There are different ratings for transmission differences--ie a 94 with an auto would be 160, but a 94 with a manual would be rated at 175. Same pump just tuned differently, I believe. If my facts are wrong or skewed, I'm sure someone will chime in shortly. Hope this helps.
Greg
stirpicult
Sep 14, 2007 12:41 PM
high00
Jan 20, 2006 10:02 PM
Big Joe
Jul 1, 2005 04:34 PM
pmtg
Mar 29, 2005 09:07 PM
zookeeper
Mar 17, 2005 05:27 PM
