need trans help, no O.D.
Old Mar 28, 2009 | 06:53 PM
OldBob's Avatar
96 12 v,260,000 miles Well I have finally had a trans problem. No overdrive.
No lockup. Wired in a switch for lockup,that works but still no fourth gear.
If I lift off the throttle while in 3 lockup,the ol truck just coasts down the road,so I assume it is releasing the direct clutch,driving on the roller clutch,but not applying the O.D.clutch. However when this first started it was intermittent and O.D. engage speed had been creeping higher.So,have I cooked the O.D. clutch,had a solenoid failure or do I have a TPS issue?
96 12v 3500 drw 4wd 260,000 unmolested miles. Thanks in advance for your help.
Old Mar 29, 2009 | 07:10 AM
Valv's Avatar
Try to shift by hand and put it in N for a second or 2 before shifting in D
Les Eid
Feb 13, 2008 09:22 AM
Racerx296
Aug 28, 2006 12:42 PM
SportTruck
Sep 5, 2004 11:37 PM
2500TurboDodge
Aug 10, 2004 10:06 PM
pancho05
Aug 18, 2003 12:20 PM
