Movement at the TPS shaft
Old Aug 29, 2015 | 04:16 PM
fschiola's Avatar
Is there supposed to be a side to side movement where the cables hook onto the spring? I'm concerned that there is a lot of movement and I'm wondering if this will affect the TPS readings to the ECM and possibly cause the transmission to not up shift from a stop sometimes.
Old Aug 30, 2015 | 02:51 PM
patdaly's Avatar
Time to rebuild your bracket............
Old Aug 31, 2015 | 05:00 PM
fschiola's Avatar
Here's an update. Both bushings were intact and in surprisingly good shape. What I did find however was the shaft had room on the back side of the plate underneath the clip. I had a very thin brass washer the right size and added that to the washer already back there and it's tight as new. As a side benefit, I found a return spring that was broken and repaired it.
whosdunit
May 17, 2014 08:54 AM
marksblaster
Jul 15, 2013 07:57 PM
mrwaters
Jun 27, 2005 07:56 PM
Mexstan
Nov 27, 2004 02:24 PM
md11jetdriver
Mar 22, 2004 06:08 AM
