More Idle??
Old May 7, 2007 | 11:02 PM
walkram42's Avatar
More Idle??
Sorry to ask the same questions as many others have asked. I searched the forum and could not find an answer. My idle is too low to run the A/C. Tried to adjust my idle. After I got the nut loose, the bolt turned less than a 1/4 turn then stopped. Is it possible that the low idle adjustment is backed out all the way to the lever stop. I have a haynes manual, that was the only thing that looked reasonable. If this is the problem, what options do I have for turning the idle up.
Thanks
Old May 7, 2007 | 11:05 PM
WildBill's Avatar
How far did you back off the locknut? It might have bound up when you tried to adjust it. You were turning the stop bolt counter-clockwise right?
Old May 7, 2007 | 11:30 PM
walkram42's Avatar
I was turning it counter-clockwise. The locknut was backed off At least 2 turns. I know because that was my first thought when it stopped.
Old May 8, 2007 | 08:27 AM
berner's Avatar
Is there crud or rust on the bottom of the bolt? Did you try to hold the throttle open a bit when turning the bolt? The top of the bolt tends to get a groove worn in it from the throttle lever and makes adjusting the idle a little touchy.
Old May 8, 2007 | 10:59 AM
walkram42's Avatar
I was not aware of the throttle lever rubbing on the bolt.
Thanks
Old May 10, 2007 | 07:26 PM
Skywalker's Avatar
You could just do away with the adjust screw altogether. After my s-shaped bar (throttle linkage bar?) broke I went to the hardware store and replaced it with a turnbuckle and put a "lock nut" on it. Now all i have to do is loosen the lock nut and twist the buckle, quick and easy.
JyRO
Jan 20, 2006 09:28 AM
robox
Oct 18, 2005 07:38 PM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
