Main bearing question
I Just greased the bearing on my idler pulley yesterday. This is my 2nd Dodge CTD and I have had to do this routinely on both. On both trucks it squeals badly in the spring. I think it has something to do with the humidity and warmer temps.
Pull the idler off get, a T50 torx and pull the pulley off the idler. Take a pick and gently remove the seals without piercing them, pack with some good grease, reseal, reassemble, repeat as needed. Or you can buy a new idler pulley for more then $100-150. I'm too cheap I just lube the old one as needed.
I'd like to replace the bearing on the pulley but I don't think it can be removed without damaging the pulley. It looks like some kind of composite material or pot metal or something.
Heykw - I'll put my money on tensioner idle pully is worn and running belt a few thousands of an inch ouit of align. Believe autozone has pully for around 70 dollars or so.
hovisimo
Dec 8, 2012 09:20 AM
wadecool
Jan 12, 2007 11:39 AM
Joseph H. Smith
16
Jan 6, 2007 08:13 PM
jaconst
Apr 2, 2006 03:02 PM
