Lower Engine Oil Leak
I have a 1996 12v with 174k on it, and I know it is normal for older trucks to leak a little bit of oil. But I just do not like leaving drips of oil everywhere I go. At first I replaced the Drain plug because the old one was cracked...I also replaced the rubber washer that goes with it. I does not appear any oil is leaking from there as I have it as tight as possible. Where do you guys think its coming from.... My best guess is the oil pan gasket has failed and it is just barely coming out form where the gasket meets the block...and the seal between the gasket and pan has failed. What do you guys think, thanks alot, Tom.
Mutt68
Mar 1, 2012 07:10 PM
xxwildbillxx
Aug 8, 2008 06:35 PM
dj_souvlaki
Mar 13, 2008 06:13 AM
smog2001
Aug 10, 2007 09:32 AM
