Low-side A/C system fitting?
Old Jun 5, 2005 | 04:30 PM
96_12V's Avatar
If the Low side A/C fitting the one located just next to the battery on the passanger's side of the truck, near the radiator. I need to recharge the A/C on 96_12V, tried with an older setup just now. Connecting the bottle it indicated 120psi and would not take a charge. Tried charging with the engine ideling, A/C on. Is something I'm doing wrong? Thanks for the help!
Old Jun 6, 2005 | 05:59 AM
jughead's Avatar
was the compressor running. that sounds like normall pressure with compressor off. if clutch was turning could be bad valves in compressor
Old Jun 6, 2005 | 05:35 PM
96_12V's Avatar
No one else have any ideas on this? Is this actually the right fitting?
Old Jun 6, 2005 | 06:18 PM
RAM2940's Avatar
Are you sure you are on the low side. Should be the larger of the two A/C lines.( On 2001 low side is by the air filter and firewall). If you are on the low side make sure the compressor is running(pressure should be between 35 and 50 psi low side depending on outside temp.). If you are getting 120 psi with compressor running (look to see if clutch is cycling)you have something wrong.( Compressor might have equalized which means its bad). Also low side will usually have a black cap with a L on it.
BearKiller
Jun 11, 2014 11:48 PM
turbo69bird
Apr 22, 2013 10:47 PM
Subliminal
Feb 27, 2010 12:18 PM
Alan_Reagan
Jul 26, 2009 01:13 PM
cquestad
258
Jan 22, 2006 09:58 AM
