Low engine temp
Old Nov 8, 2007 | 05:33 PM
Ram95's Avatar
Low engine temp
My gauge never gets above 170. What degree of T-Stat should I be running? What would cause low engine temp?
Old Nov 9, 2007 | 10:05 AM
infidel's Avatar
Nothing is wrong
Cummins says,
THE COOLING SYSTEM USED ON THE CUMMINS DIESEL ENGINE EQUIPPED VEHICLES PROVIDES THE CAPACITY AND PROTECTION OF THE HIGHER GVWR AND GCWR RATINGS AVAILABLE ON THESE VEHICLES. OWNERS SHOULD BE ADVISED OF THE NORMAL SLOWER WARM UP AND LOWER ENGINE OPERATING TEMPERATURES ASSOCIATED WITH DIESEL ENGINES.
THE COOLANT TEMPERATURE GAUGE WILL FLUCTUATE ON DIESEL ENGINE EQUIPPED VEHICLES. IT IS INFLUENCED BY VEHICLE LOAD, OUTSIDE AMBIENT TEMPERATURE AND EXTENDED IDLE TIME. THIS FUNCTION IS CONSIDERED NORMAL
__________________
Old Nov 9, 2007 | 03:21 PM
Ram95's Avatar
Cool I'll stop worring about it.
Old Nov 9, 2007 | 06:51 PM
superuke's Avatar
wow, if you was living in Sask. you'd worry about it.. I can drive my 97 for 20 miles & barely get enough heat so that my breath inside quits blowing frost.. In the winter I must cover the rad with cardboard or the gauge would barely move up.. Changed thermostats & didn't help a bit.
MossyOakCTD
19
Dec 28, 2010 09:11 PM
smokinram99
Sep 15, 2009 01:00 AM
wvopowered
Jul 5, 2008 10:31 AM
Racing_Joe66
Jun 12, 2007 05:06 AM
firesine
Nov 24, 2005 10:58 AM
