low end boost
Old May 6, 2005 | 10:11 AM
pittom's Avatar
low end boost
how can i increase low end boost, i can't get over 10 boost until 4th then i have it set i think 35 not sure just back off some so don't get to high. My shift points are to low 1-2-3 all shift around 1800rpm any suggestions thanks
Old May 6, 2005 | 10:22 AM
Lil Dog's Avatar
I would bump the AFC housing ahead for starters and then adjust the star wheel as well. The bump forward on the AFC should help out on the bottom end grunt.
J-eh
Old May 6, 2005 | 11:56 AM
CTD NUT's Avatar
Yup, good advice.....slide the AFC housing full-forward and slacken off the AFC spring all the way......if you REALLY want a HUGE bottom end punch, add a set of 191 dv's. Remember, fuel is boost, the more fuel you have sooner, the more boost you will have sooner.....and man, 191 dv's will give you all the low end fueling you need! They won't do much for top end with just a stock injector, though.....Also, the #6 plate is not the greatest for low end punch either.....swap to a #10 to start the fueling earlier in the curve....Another option is grind your own #100 (which I prefer over a #10) but at this point, the stock auto will not put up with all this bottom end torque - especially the TC......Be careful!!
Old May 6, 2005 | 02:44 PM
pittom's Avatar
sorry forgot to put that in AFC housing is full-forward. What does #100 plate look like so i can do my own. I plan on geting a tc and teans kit or valve body,will that hold up?
Old May 6, 2005 | 10:54 PM
CmminsBeast's Avatar
When you talk about moving the afc housing forward, is that different from moving the cam plate forward?
Old May 8, 2005 | 09:44 AM
pittom's Avatar
yes, the plate is under the afc housing
Old May 9, 2005 | 08:42 AM
CTD NUT's Avatar
Do a search for "#100 plate" and you will have lots of reading and some pics - it is not hard at all to grind a #100. Yes, a good TC and VB kit will go a long way to helping the tranny work well with all that extra torque.....don't skimp on the TC, it is the most important tranny upgrade. Have you slackened off the AFC spring?
Old May 10, 2005 | 07:21 AM
pittom's Avatar
no
cali4niacoalrlr
Apr 1, 2014 09:22 AM
daveg
13
Feb 1, 2008 11:05 PM
RAMRODD
0
May 23, 2006 10:08 PM
spitzair
Jan 24, 2006 03:42 PM
