Lost boost
Lost boost
I installed a 3K gsk and straight piped my truck during the first week of this month. Since that time I have noticed that I have lost about 10psi of peak boost during long WOT runs. I have also lost about 5psi of boost during short blasts. Could the GSK be causing this? Or is the open exhaust effecting the way the turbo spools? <br><br>Thaanks in advance.<br>Joe<br><br>PS It also feels like I have lost some HP towing as well.<br><br><br><br>(Note to Mod.: Feel free to move this to a more appropriate forum if needed)<br>
Re:Lost boost
One would think the turbo would spool up quicker?? Would the gsk affect this? Can't answer. Do you have a boost gauge? I wonder if now you have to increase the boost due to the changes (changes require more boost). But don't take my word for it. Let others with more knowledge reply. Just trying to give you ideas. Kevin D.
Re:Lost boost
when I changed my exhaust from the factory to gutting the cat and installing a performance muffler I could tell a difference in the power especially down low in the rpms but I did not have a boost gauge at that time so I do not know what it did to the boost just add a fuel plate, better injectors, better air cleaner and you will be ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
Re:Lost boost
Gov, lever needs to be adjusted.<br>It being out of adjustment will cause you to lose boost.<br>After changing the springs it prob. will need to be adjusted.<br>It should be looked at after a plate swap, but nobody does.<br><br><br>I do ! ;D<br><br> : Eddie : 8)
ClawHammer
Aug 7, 2004 08:49 AM
mysterync
Jan 16, 2004 05:09 PM
I am exploring other options.
